apply unsharp mask to layer without affecting feathered edge
When I draw a mask round an object and feather the edge, then apply unsharp mask, it also tries to sharpen the feathered edge which screws the edge up.
How can I sharpen everything inside the mask without sharpening the feathered edge?
I want to use unsharp mask and no other sharpening effect.
As a work around I am currently rendering the whole layer as an uncompressed avi with unsharp mask applied, then I’m going to re-import that footage to replace the original, then I will add the mask with the feathered edge.
