Activity › Forums › Adobe After Effects › Apply Tracking to Matte in a layer?
Posted by Eric Goldstein on August 15, 2009 at 12:02 amHi,
Is it possible to track an object in a layer and then apply the track only to a matte, not the entire layer?
Eric
Jim Dodson replied 17 years, 1 month ago 2 Members · 2 Replies -
Jim Dodson
August 15, 2009 at 12:39 amBy a “matte” do you mean a mask?
Jim Dodson
8 Core Intel — Mac – OSX
Jim Dodson
August 15, 2009 at 12:57 amAssuming you do mean that you want to apply tracking data to a mask, heres one way you can do that:
Create a new null. Apply your tracking data to the null.
Now create a new black solid — make it approx 25% bigger than your comp setting in both height and width. Now paste your mask to this solid. Make sure this solid layer is directly above the video layer that you want the mask to affect. Now set the video layer’s track matte to “alpha matte” of the black mask solid (or depending on what you want possibly inverted alpha matte).Now, using the pickwhip, parent the black solid to the null that has the tracking data.
(You needed to make the black solid bigger than your comp solid otherwise, as the solid moves around based on your tracking data, the edges of the solid would mess up your matte).
Does this help??
Jim Dodson
