Activity › Forums › Apple Final Cut Pro Legacy › apply Strobe to moves made in Motion tab w/out nesting?
  • apply Strobe to moves made in Motion tab w/out nesting?
    Posted by Paul Dougherty on September 9, 2011 at 1:58 pm
    I’m fiddling with both the Video & Time versions of Strobe (not sure of diff) as applied to a rapid photo-mation move I’ve set up with keyframes in the Motion tab. (I’ll be doing a lot of this)
    The only way I can get it to work is to make the photo-mation bit its own seq and then edit that seq into the main seq – then apply Video Strobe (nesting). I’d love to be able accomplish this without nesting, is that possible?
    Thanks in advance,
    Paul
    Jonan Grobler replied 14 years, 12 months ago 2 Members · 3 Replies
  • Jonan Grobler
    October 5, 2011 at 12:51 pm
    Are you just keyframing position in the Motion tab? More information would be cool. I see no reason why you can’t keyframe in the Motion tab and then add strobe to that clip. If you’re keyframing the Strobe filter, and want to add Strobe over that, you can just layer another copy of the filter underneath. Though I can’t think of any situation in which that would be necessary.
    Sorry. If I had more information, I could give more advice.
    Jonan
    Jonan Grobler
    Editor/Motion Graphics
    GTG MOTION PICTURES
    filmstudio.co.za
  • Paul Dougherty
    October 5, 2011 at 1:02 pm
    “Are you just keyframing position in the Motion tab?”
    Yes. Applying Strobe to that clip with position keyframes doesn’t do anything in my tests. (my strobe needs are uniform, no keyframes there)
    Paul
  • Jonan Grobler
    October 5, 2011 at 2:18 pm
    I’m sorry, I cannot help, as it works just fine in my FCP 7. What exactly is causing you to not be able to put Strobe on those clips?
    Jonan Grobler
    GTG MOTION PICTURES
    filmstudio.co.za
