Activity › Forums › Adobe After Effects › Apply one effect (stroke or fill) to some of multiple masks
  • Apply one effect (stroke or fill) to some of multiple masks
    Posted by Marie Bauni on April 15, 2025 at 11:16 pm
    I have 150 masks on a Solid Layer, I applied a Fill effect, but instead of duplicating this effect 150 times and add as much keyframes to control each mask.
    I would like to create a slider control, that can control on which mask the effect is applied ? Is there any possibility to do that ? So I can go from 1 to 150, and choose the good mask.
    Then I would like to expend that choice, and select 3 masks at a time, from 1-3, then 2-4, etc. With the same process ?
    I think maybe with some expressions with the Index or something, but I can’t find it.
    Thank you 🙂
    Brie Clayton replied 1 year, 5 months ago 4 Members · 5 Replies
  • John Martin
    April 16, 2025 at 1:24 pm
    i’m recording a video answer for you with the solution ❤
  • John Martin
    April 16, 2025 at 1:58 pm
    4 U!
    you find the file in the video’s description
    https://youtu.be/sCtizpjYtF4
  • Marie Bauni
    April 16, 2025 at 3:20 pm
    Waow !
    You’re awesome ! Thanks a lot. 🙂 That’s perfectly what I was looking for.
  • Roland R. kahlenberg
    April 17, 2025 at 11:39 am
    John Martin for President!!!
    :-D🍾
  • Brie Clayton
    April 17, 2025 at 12:43 pm
    Thank you for solving this, John!
