Activity › Forums › Maxon Cinema 4D › Apply motion tracking data to object
Posted by Paul Rijkaard on January 15, 2016 at 6:17 pmIs it possible to apply the tracking coordinate data from a solved camera onto another object or a light?
Adam Trachtenberg replied 10 years, 8 months ago 2 Members · 3 Replies -
Adam Trachtenberg
January 15, 2016 at 6:38 pmSure, the most direct way would be to place your object as a child of the tracked object. Otherwise you could use Xpresso or a constraint tag.
Paul Rijkaard
January 15, 2016 at 7:09 pmok thanks, just to make sure I have explained myself fully, I would like a spot light to pivot and move with the same coordinates as a solved camera. I think, this is not the same as a tracked object, but I am probably wrong??
Adam Trachtenberg
January 15, 2016 at 7:17 pmYeah, same thing. What I’d do is make a null a child of the camera and then place the light inside the null, offset to the position you want it.
