Activity Forums Adobe After Effects Apply LUT effect
  • Apply LUT effect
    Posted by Jim Bachalo on July 1, 2011 at 9:57 am
    The documentation for apply LUT effect is pretty limited.
    I was wondering if there were any AE compatible LUTs available for download I might be able to use for color grading.
    Local is the new global
    Walter Soyka replied 15 years, 2 months ago 3 Members · 6 Replies
  • Walter Soyka
    July 1, 2011 at 12:43 pm
    [jim bachalo] “I was wondering if there were any AE compatible LUTs available for download I might be able to use for color grading.”
    LUTs are usually used to communicate color grades from one system to another (for example, a colorist could send a LUT to a compositor).
    Some systems use LUTs for color management, but the After Effects color management system is built around ICC profiles — a far more flexible and elegant system, in my opinion.
    What exactly is it that you want to do with LUTs?
    Walter Soyka
  • Jim Bachalo
    July 1, 2011 at 1:55 pm
    Was under the impression that you could use LUTs for color curve presets, to save certain looks.
    There are certain looks I am trying to match using curves but having a difficult time.
  • Walter Soyka
    July 1, 2011 at 2:17 pm
    [jim bachalo] “Was under the impression that you could use LUTs for color curve presets, to save certain looks.”
    You absolutely can — with the proviso that a LUT is limited to translating one table of colors directly to another — but I don’t know of anyone sharing LUTs online as artistic presets. (Of course, that doesn’t necessarily mean they’re not out there.)
    Again, though, I think LUTs are mainly used as technical, system-specific tools for working with particular cameras, displays, or film stocks.
    If you want to save a LUT from AE, check out Red Giant Software’s free LUT Buddy [link].
    [jim bachalo] “There are certain looks I am trying to match using curves but having a difficult time.”
    Curves may not be the best tool for the job — can you post some stills showing the look you’re going for, and the footage you’re working with? Maybe we can help.
    Walter Soyka
  • Michael Szalapski
    July 1, 2011 at 2:34 pm
    You could set up a preset for the look you want.
    Now, the problem comes if the underlying footage varies. This (old) tutorial [link] may help.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Jim Bachalo
    July 1, 2011 at 11:56 pm
    Thanks Walter.
    LOTS of looks I’d like to be able to match using only curves.
    Here are 3 that spring to mind!
    1-old Kodachrome from Library of Congress (I tried all the film presets in Color Finesse but none come even close)
    https://www.flickr.com/photos/library_of_congress/sets/72157603671370361/
    here’s 1 favorite
    https://www.flickr.com/photos/library_of_congress/2178345695/in/set-72157603671370361
    besides the obvious crushed blacks, not sure how to best approach this using curves.
    love the look of a few of these Canon picture style presets
    here’s 2 I really like
    2-WEDDING
    https://www.flickr.com/photos/kevin32832/4976572653/in/set-72157624924507322/
    3-LOMO
    https://www.flickr.com/photos/kevin32832/5097430548/in/set-72157625199074416/
    I’m pretty sure its possible to approximate these looks using RGB curves only, but I could be wrong.
    Perhaps in conjunction with another effect or setting in Color Finesse?
    Woman aircraft worker, Vega Aircraft Corporation, Burbank, Calif. Shown checking electrical assemblies  (LOC)
  • Walter Soyka
    July 5, 2011 at 1:52 pm
    [jim bachalo] “I’m pretty sure its possible to approximate these looks using RGB curves only, but I could be wrong. Perhaps in conjunction with another effect or setting in Color Finesse?”
    Why limit yourself to Curves in Color Finesse? I think the HSL controls are quite a bit more approachable for manipulating hue, and the CMY controls might be worth looking into for emulating older film stocks.
    I think that these looks will be next to impossible to achieve with primary color correction alone — secondaries will make this a lot easier.
    Walter Soyka
