Activity Forums Maxon Cinema 4D Apply FBX or AXYZ Mocap Data to Non-Human Object
  • Apply FBX or AXYZ Mocap Data to Non-Human Object
    Posted by Hayden Martin on November 2, 2015 at 5:18 pm
    Hi
    I am trying to figure out how to apply the mocap data from AXYZ to inanimate objects. A good starting point could be a sphere or cube – how can I assign areas of the object to an arm or leg of the AXYZ rig?
    Initially I thought this could be possible by using the FFD or Correction Deformers and simply assigning nulls influenced by AXYZ points to areas on the deformer cages.
    This would create a cartoonish look that could be quite interesting to experiment with.
    Hayden
    Adam Trachtenberg replied 10 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 2, 2015 at 5:36 pm
    I’m not familiar with AXYZ, but presumably you could use Xpresso and/or Constraint tags. In Xresso you can use point nodes to move points to other objects’ or points’ positions.
