Activity Forums Adobe Premiere Pro Apply an effect to clips and replaced in timeline
  • Apply an effect to clips and replaced in timeline
    Posted by Joseph Freeman iii on April 7, 2018 at 10:00 pm
    In Premiere Pro CC2018, is there a way to take an existing project and apply an effect, such as denoiser,
    to multiple clips and replace the existing clips with the corresponding new clips in the project timeline?
    Alternatively, can an effect be applied, on Ingest, to a file?
    Thank you.
    Joseph Freeman iii replied 8 years, 4 months ago 1 Member · 1 Reply
  • Joseph Freeman iii
    April 9, 2018 at 2:39 pm
    I had to compromise (an extra generation) and replace the clip (ProRes) with an after effects composition, apply denoiser, and in Premiere Pro do a render and replace (DNxHD)…This process was repeated for every cut needing denoiser.
    In After Effects, I created an Animation Pre-set to minimize key strokes and reduce possibility of user error.
