Activity Forums Adobe After Effects Expressions apply a scale expression to 100 layers
  • apply a scale expression to 100 layers
    Posted by Andrew Riss on June 21, 2010 at 12:39 am
    I need to apply the same scale wiggle to 100 layers.
    is there an easy way to do this w/o twirling the arrow for scale
    and cutting and pasting he expession into each layer?
    w = wiggle(3,50);
    [w[0],w[0]]
    Dan Ebberts replied 16 years, 2 months ago 2 Members · 2 Replies
  • Andrew Riss
    June 21, 2010 at 1:13 am
    neverminfd
    I figured it out
    I made it a preset
  • Dan Ebberts
    June 21, 2010 at 2:32 am
    That’s one way. You could also select the property with the expression, do Edit > Copy Expression Only, select all the other layers, and paste.
    Dan
