Activity Forums Maxon Cinema 4D Applied video to a material and now want to have that material scale properly onto an object
  • Applied video to a material and now want to have that material scale properly onto an object
    Posted by Craig Ricker on April 16, 2012 at 1:37 am
    So basically, i’ve got a 1280 x 720 video and would like to put it on the face of a cube. The size of the cube face is not 1280 x 720, so i’m trying to work out how to get the video to scale down to the size of the cube in cinema 4d.
    At the moment, it just shows part of the video material.
    I could reduce the size of the video in after effects, but surely there is a way to get the material to scale down so it fits the cube?
    Any ideas?
    Craig Ricker replied 14 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    April 16, 2012 at 1:10 pm
    The easiest way to do it, IMO, is to set the width/height proportions appropriately in your editing or compositing application. In this case you would pad the top and bottom to make the footage square. You might also want to scale it down if you don’t need the full resolution in Cinema. Output to a frame sequence instead of a compiled movie format to speed up playback in Cinema.
    Then load your footage in a material and apply it to the polygon. Click on the newly-created texture tag and set the projection to flat. You may have to use the texture axis tool to rotate the mapping so that the Z axis is pointing the right way. Then, right click on the texture tag and select “fit to object”. That will assign the exact scale and position you need.
    If you don’t want to make the texture/footage square first you can follow a similar procedure, but you’ll have to to do some manual positioning and scaling. You can get the aspect ratio right by adjusting the scaling in the texture tag (e.g. set it to x: 128%, y: 78%). Then scale uniformly in the texture axis tool and move into position.
  • Craig Ricker
    April 17, 2012 at 1:54 am
    Thanks mate this worked out perfectly!
