Activity Forums Apple Final Cut Pro Legacy Application Quits on mixdown HELP
  • Application Quits on mixdown HELP
    Posted by Boco007 on January 26, 2006 at 8:31 pm
    Hi Guys, I have tried everything. I used the FCP fix and I broke the project down and tried to mixdown. I trashed the preferences. I trashed the render files and re-rendered. I can not get a mixdown. I was told that maybe the RAM was bad on the G4 (it still may be) so I moved the project over to my G5. It still quit the application on mixdown. I just don’t get it. I can’t burn a QT without mixing down. I even tried to use Media Manager to make a copy and the application quit there also! So it must be in the project? If it is a corrupted file how can I find it? Why else would it do the same thing on two different computers? help, please.
    Jerry Hofmann replied 20 years, 7 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    January 26, 2006 at 10:27 pm
    If you can make a QT movie, don’t fight it… just do that, and import the file back and put the audio in your sequence from that? It’s a bad media file (audio probably) dollars to doughnuts…
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
