Activity › Forums › Creative Community Conversations › Apple Tech Support responses to FCPX thumbnail issues
  • Rob Mackintosh
    December 14, 2011 at 5:43 am
    What about this from the same post:
    Q: Are multiple projects in the project library continuing to be processed while working on a current open project, thus impacting the performance of FCPX?
    A: YES…things such as rendering thumbnails or effects that have not been completed while the project was open will continue to be processed in the background, even though they are not the currently opened project.
    WTF? They haven’t prioritized UI responsiveness.
    Ironic considering iOS shines in this area compared with Android
    Check his system specs
    Bought a new mac pro 12 core with 48 gig ram and two 500 gig solid state Crucial M4 drives.
    If he’s having problems . . .
  • Aindreas Gallagher
    December 14, 2011 at 9:49 am
    Generally smaller clip sequences usually render pretty fast.
    Sigh. Ah man. It really is toast. They’re not fixing this thing. It’s the blasé way he says that.
    It’s like – “yeahhh it’s a bit of a crock, but if you keep it simple and short it should work ok.”
    It really is a serious flaw, and their guidance is not to use long clip sequences.
    You’re holding it wrong.
    http://www.ogallchoir.net
    promo producer/editor.grading/motion graphics
  • Fredy Schwerdtner
    December 14, 2011 at 2:38 pm
    I recently was doing an import from camera with some HDV material and after the import, FCPX was taking too long doing the “thumbnail thing”. I decided to close it. It said that some background tasks were not finished. I closed anyway and reopened. When it came back it showed the tasks “idle”.
    iMac 2.7 GHz Intel 4 Core i5
    16 GB memory
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    6GB 667 MHz DDR2 SDRAM
    OWC RAID 5 with 3TB
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.6.5
    Final Cut Studio “3”
  • Rob Mackintosh
    December 15, 2011 at 12:40 am
    On reflection (and reading Ben Balser’s response to his post) some of the advice he received might be BS.
    That said, the performance of FCPX is still a real concern and a deal-breaker for me continuing to use it.
  • Dan Wierling
    December 28, 2011 at 6:43 pm
    Hey, all..
    I am the original user that called Apple and started that post. I am glad it has gotten all the attention it has, because in the many comments people made, many answers were revealed.
    I can tell you that at the time I wrote the post, I had only been using FCPX for a couple weeks. I had over 16 long DV projects open and based on other user comments and Apple’s recommendations, moving them to allow working on one or two made a hugh impact on performance for me.
    I agree some of the answers I received from Apple were not convincing to me, but I thought I would let the community react and offer their opinion and expertise.
    By obtaining increased knowledge from these forums plus ongoing practical experience with FCPX, things are definitely getting better.
    Regards,
    Dan
  • Steve Connor
    December 28, 2011 at 7:12 pm
    [Aindreas Gallagher] “It really is a serious flaw, and their guidance is not to use long clip sequences.
    You’re holding it wrong.”
    FCP had exactly the same problem in it’s earlier versions
    “My Name is Steve and I’m an FCPX user”
