Activity › Forums › Adobe After Effects › Apple prores codec issue
Posted by Scott Gaskin on June 14, 2015 at 3:09 pmHi,
I’m trying to find a way to install the apple prores 422 (HQ) codec for After Effects. When googling the question I am told to go to the apple website: https://support.apple.com/kb/DL1396 but I can’t see an option to download?
Can anyone one help?
Thanks in advance
Scott
David Mcgavran replied 11 years, 2 months ago 4 Members · 6 Replies -
Tero Ahlfors
June 14, 2015 at 5:18 pmYou should have the codec under the Quicktime codecs if you are on a Mac. If you are on a Windows you can’t export to prores with AE.
Scott Gaskin
June 14, 2015 at 7:22 pmHi Tero,
I do not have the prores option when exporting from After Effects. I have been following a tutorial on how to clean up dslr footage and export to prores ready for grading/colour correction. In the format options it appears as an option on the tutorial but not in my options through AE.
Any ideas?
Regards
Scott
Scott Gaskin
June 17, 2015 at 7:32 pmThanks Dave,
The page seems to have loaded correctly now. Originally I was getting that issue where the style sheets hadn’t kicked in leaving an ugly html syntax looking page where I could only see the bullet points and no clickable links!
Doh! -
David Mcgavran
June 17, 2015 at 10:51 pmFor 10.9 (I think) onwards you don’t need to have any Pro Video Codecs installed to use ProRes. It is always there on the mac. Just not on Windows.
CheersDave
David McGavran, Adobe Systems Incorporated
Senior Engineering Manager Adobe Premiere Pro
