Activity Forums Apple Final Cut Pro Apple ProRes 422 in FCPX, CinemaTools or Compressor?
  • Apple ProRes 422 in FCPX, CinemaTools or Compressor?
    Posted by Özgür Akyıldız on April 27, 2013 at 10:16 pm
    Hi again,
    I guess the topic tells it all but is there a difference converting H.264 to Apple ProRes422 in FCPX (create an optimized media), Compressor or Cinema Tools? Pros and Cons etc.
    Thank you in advance guys!
    David Eaks replied 13 years, 4 months ago 3 Members · 2 Replies
  • Bret Williams
    April 28, 2013 at 4:05 am
    Less room for error in X. Plus it keeps track of the originals and all the metadata etc. When the project is done you could just dump the ProRes and only backup the h264 related to the final sequence. The PtoRes is just for (supposedly) better performance while editing, although I haven’t seen any. But perhaps if you’re editing on a lesser machine like a MacPro instead of an iMac, then it would be more visible. 🙂 Sadly there is a lot of truth in that.
  • David Eaks
    April 28, 2013 at 7:57 am
    Plus, if you do it in FCPX, you can start working with the H.264 files right away. When the transcode has finished just keep working, it’s already using the Prores files in the timeline.
    FWIW, I definitely notice a difference in performance between Prores and H.264 (on my 2008 Mac Pro and 2010 17″ i7 MBP), especially with Multicam clips. As Bret said, it is to be expected.
