Activity Forums Apple Final Cut Pro Legacy Apple Prores 422 Crossdissolve or fade to black issue
  • Apple Prores 422 Crossdissolve or fade to black issue
    Posted by Jesus Silva on January 27, 2011 at 1:02 am
    Hello there,
    I’m working on a project 1920×1080 23.98 Apple Prores 422 on FCP 6.0.6, running QKtime Version 7.6.4 (518.35), MAC OS X 10.5.8, 2.66 Quadcore machine, 8GB RAM.
    Sequence setting at matching the footage format. Video processing at 10b-bit.
    The material was shot with the Canon 5D at the same specs.
    Brought in FCP thru log and transfer.
    After exporting a highress self-contained Qktime I have notice there is a weird effect on the cross-dissolve. There is a small jump on the video levels (maybe gamma?) when entering the dissolve. I have also tried to do the fade manually with the opacity but with the same results, also tried to change the sequence video processing to 8-bit and no luck either.
    Any leads?!
    THanks!!!
    “Equations are more important to me, because politics is for the present, but an equation is something for eternity.”
    Albert Einstein
    Jesus Silva replied 15 years, 7 months ago 3 Members · 3 Replies
  • David Roth weiss
    January 27, 2011 at 1:18 am
    Check to make certain that “full” is checked in the Render All menu, then re-render the sequence.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Shawn Bann
    January 27, 2011 at 1:47 am
    Possibly color sync?
    Quicktime> Prefs> Enable Final Cut Studio color compatibility
  • Jesus Silva
    January 27, 2011 at 2:44 am
    Checked! Still the same no difference, there is a jump on the image levels or what looks like the a gamma change when the cross-dissolve comes in. ???
    Albert Einstein
