Activity Forums Adobe After Effects apple pro res 422
  • apple pro res 422
    Posted by Andrew Marshall on January 27, 2009 at 6:59 pm
    I am rendering out elements for a delivery, using apple Pro Res 422. They unfortunately requested things delivered with interlaced fields. I am delivering upper fields, 29.97 or (59.94 if you consider the fields)
    My issue is in AE I can set up the upper fields and have rendered some elements out that way. When looking through some of the settings I found that the compressor its self has settings for interlacing, and wants top or bottom fields.
    If I change this setting in the compressor, will it play ok with the files that I have already rendered? I would be using the upper fields option within the AE Render Settings, and additionally setting up the codec for fields.
    -rendering.
    Andrew Marshall replied 17 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
