Activity Forums Blackmagic Design Apple “NONE” Codec
  • Apple “NONE” Codec
    Posted by Tarquin Douglas on April 7, 2009 at 8:46 pm
    We have just moved onto a Blackmagic SDI card from an AJA card. I have always used NONE to capture in our (mostly) PAL footage. Does anyone else capture in using Apple NONE?
    I am not sure but on one recent job there seemed to be higher levels of black in our Quicktime captured file (which ened up as an MPEG 2 on a DVD).
    What is the best codec to capture in using the Blackmagic SDI card for the closet match to source material on a digibeta?
    Any work flows you use would be great to know.
    Cheers,
    T
    Tarquin Douglas replied 17 years, 5 months ago 2 Members · 2 Replies
  • Scott Thomas
    April 7, 2009 at 10:17 pm
    I thought the NONE codec was an RGB codec?
    Uncompressed 10bit would be the closest to the source material.
    I would use the Animation codec for RGB material. It supports an alpha and uses a lossless compression to make the files a little smaller.
  • Tarquin Douglas
    April 8, 2009 at 1:39 pm
    Many thanks,
    T
