Activity › Forums › Apple Motion › Apple Motion and vector images
Posted by Alex Ordiner on October 28, 2009 at 11:21 amfirst of all – sorry for my “google” english
second: I need to work with vector images, but I noticed that Apple Motion accepts only pdf images. Is it right?
I try to convert AI or SVG files with Automator, but I failed.
Thanks. Alex
Mpigott replied 16 years, 9 months ago 3 Members · 16 Replies -
Stephen Smith
October 28, 2009 at 2:13 pmYou can import AI files into Motion and if set right you can maintain its vector quality.
Your Illustrator file needs to be RGB and not CMYK. Be sure to save the AI file with PDF compatibility. After you bring it into Motion, just select it, press Shift+F (takes to you the Media tab), then uncheck the Fixed Resolution checkbox. This will allow the vector image to be rasterized at whatever size it is on-screen. Hope this helps.
Check out the Graphics Demo Reel I did.
Check out my Motion Tutorials
Alex Ordiner
October 28, 2009 at 2:27 pmthank you very much Stephen!
I knew the “fixed resolution” checkbox, but not the AI – CMYK incompatibility..
So, I just have to find an automatic way to convert them.thanks to you and to all of you!
Alex -
Stephen Smith
October 28, 2009 at 3:27 pmHappy to help. Do you have access to Adobe Illustrator?
Alex Ordiner
October 28, 2009 at 3:37 pmyes I do. In bundle with AE
But I not found any kind of batch operation
Stephen Smith
October 28, 2009 at 4:09 pmSo you have a bunch of AI files you want to convert over to RGB?
Alex Ordiner
October 28, 2009 at 4:32 pmyes, a no pdf-compatible vector icon format.
I also have a lot of .svg
but tomorrow i wil try to record an action with automator (mouse action record)…
I hope it works
Thanks again
Stephen Smith
October 28, 2009 at 7:41 pmSounds like a great idea. Let us know if it works.
Mpigott
November 4, 2009 at 9:16 pmI came out of my Windows illustrator as a PDF compatible .ai file.
Apple Motion will not read the CS4 noway-no how.
Is it another…”gee, you better buy the Mac version of the Adobe Suite” ???? -
Stephen Smith
November 4, 2009 at 9:34 pmCan you upload an AI file so I can take a look at it? Use the File Upload button which is the last icon that is a floppy disk symbol.
Mpigott
November 5, 2009 at 9:53 pmLet me ftp it- the uploads don’t work here.
Just email me and I will set up an ftp here at work
