Activity Forums Adobe After Effects Apple Magnification Effect with 3D LAYERS
  • Apple Magnification Effect with 3D LAYERS
    Posted by Gabriel Rocha on February 22, 2016 at 8:17 pm
    Hello Everyone, i know a lot of people asked about this already, but im trying to achieve this effect in a 3D environment in AE. Like a carroussel of Elements rotating in 3D, and when the get close to another 3D layer they magnify (Scale up).
    I found a way to do this in 2D in several posts here, but not with 3D layers.
    Can anyone help?
    Thank you!
    http://www.gabrielrocha.com
    Chris Evans replied 10 years, 6 months ago 2 Members · 3 Replies
  • Chris Evans
    February 22, 2016 at 10:28 pm
    I’m not quite sure I understand what you’re trying to achieve. I know I did a project just a little while ago where I used a 3d layer with the magnification effect on it. And in order to get it in the shape of another layer, I precomped that layer (with the 3d layer inside it), collapsed transformations and used it as a track matte for the adjustment layer with the magnify effect.
    I don’t know if that helps you though because I’m not quite sure what you’re trying to achieve.
  • Gabriel Rocha
    February 23, 2016 at 12:53 am
    Kind of. But nothing to do with shapes.
    This is the effect basically:
    https://youtu.be/xDuKoaLpXOY?list=PL0F5968389930868B
    BUT it have to work on 3D space, so when the layer gets closer to the other it Scales UP ( like Magnification effect). It doesnt matter from which direction it’s coming from, X, Y or Z.
    Thank you.
  • Chris Evans
    February 23, 2016 at 3:25 am
    Ahh, I see. Unfortunately I don’t know enough about expressions to help with that.
