Activity Forums Avid Media Composer apple compressor
  • apple compressor
    Posted by John Thomason on October 4, 2017 at 6:35 am
    I need to compressor my MC timeline to H.264 I already have compresses on my Imac .has anyone used this on MC. I know Squeeze is available but I don’t want to pay for it if I don’t have to. What is your work flow if you are using compressor
    Brent Marginet replied 8 years, 11 months ago 3 Members · 2 Replies
  • Michael Phillips
    October 4, 2017 at 12:16 pm
    Should be the pretty close to the same workflow – export a QT reference, QT Same as Source, or MXFOP1a and open in Compressor with your desired output settings and export. I use Adobe Media Encoder rather than Squeeze since I already have that and the process would be similar.
    My reasons for using MXF OP1a are in my blog: https://24p.com/wordpress/?p=278
    Michael
  • Brent Marginet
    October 5, 2017 at 3:26 am
    You could always export an H.264 directly out of Avid.
    If you want to use Compressor then export a ProRes or DNxHD QuickTime out of Avid and then run it through Compressor.
    \”MY MEDIA/PROJECT MOTO: If you think three copies of your media or project are enough.
    Take a moment to place a value on them and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
