Activity Forums Apple Motion Apple Compressor 4.4.1 – TGA Image Sequence
  • Apple Compressor 4.4.1 – TGA Image Sequence
    Posted by Burhan Aksendir on October 4, 2018 at 3:01 pm
    I’m using the latest version of Compressor 4.4.1.
    Whenever I select any video and try to export it as a TGA Image Sequence, I always get this error:
    “Failed: Failed to write the image file.”
    Is there a solution to this problem? I can’t find information, unfortunately.
    Mark Suszko replied 7 years, 11 months ago 4 Members · 11 Replies
  • 11 Replies
  • Robin S. kurz
    October 5, 2018 at 8:37 am
    Have you changed the destination?
    – RK
    ____________________________________________________
    Deutsch? Hier gibt es ein umfassendes FCP X Training für dich!
    Youtube | Facebook
  • Burhan Aksendir
    October 5, 2018 at 3:44 pm
    Yes. I’ve tried. But the result is the same: “Failed…”
  • Matt Galuszewski
    October 5, 2018 at 11:52 pm
    [Burhan Aksendir] “Yes. I’ve tried. But the result is the same: “Failed…””
    Same for me here for TGA image sequence
  • Burhan Aksendir
    October 6, 2018 at 4:09 pm
    I think this is a bug.
  • Robin S. kurz
    October 7, 2018 at 8:07 am
    Is there any particular reason why you need to be doing this via Compressor? Does it not work using FCP?
    – RK
    Youtube | Facebook
  • Burhan Aksendir
    October 8, 2018 at 3:56 pm
    I need to export TGA image sequence. That’s why I use Compressor. I’ve also tried over FCP and Motion. The result is the same.
  • Robin S. kurz
    October 8, 2018 at 4:05 pm
    So you’re saying you’re getting the exact same error message from all three? That of course would be very odd. I only know that it’s fine here.
    Exporting as a PNG, TGA, PSD or whatever else sequence is not an option?
    – RK
    Youtube | Facebook
  • Burhan Aksendir
    October 8, 2018 at 10:21 pm
    I tried again. I only get this error in TGA option. Other options are no problem. My client wants me to deliver it as a TGA Image Sequence. How can I do it? Is there a way?
  • Robin S. kurz
    October 9, 2018 at 4:19 pm
    Well, I’m unfortunately lost then, sorry. I just know that it works just fine here in all three. Compressor, FCP and Motion…
    There’s always the Quicktime 7 Player and possibly MPEG Streamclip? Handbrake?
    – RK
    Youtube | Facebook
  • Burhan Aksendir
    October 9, 2018 at 6:04 pm
    I installed Compressor 4.2.2 and I solved the TGA Image Sequence issue.
