Activity › Forums › Apple Final Cut Pro Legacy › apple click
apple click
Posted by John Barnard on April 2, 2008 at 8:44 pmCan anyone tell me why on my final cut 6 system, I can command-click to select and adjust the in/out point on only one track, but I can’t do this on my final cut 7 suite?
It’s driving me nuts and I can’t figure it out.
THanks
Blackmagic Multibridge
Final Cut 6
Mac Pro
Model Identifier: MacPro1,1
Processor Name: Dual-Core Intel Xeon
Processor Speed: 3 GHz
L2 Cache (per processor): 4 MB
Memory: 3 GB
Bus Speed: 1.33 GHz
SONY HRV – D1800 HDCAM deck
SOND HRV – 1500 HDV deckJohn Barnard replied 18 years, 6 months ago 3 Members · 8 Replies -
Zane Barker
April 3, 2008 at 1:38 am[John Barnard] “Can anyone tell me why on my final cut 6 system, I can command-click to select and adjust the in/out point on only one track, but I can’t do this on my final cut 7 suite? “
Its quite simple, its because there is no Final Cut 7.
There are no “technical solutions” to your “artistic problems”.
Don’t let technology get in the way of your creativity! -
John Barnard
April 3, 2008 at 12:51 pmWell, whatever the new version is… it doesn’t seem to do that command click trick.
Final Cut 6
Mac Pro
Memory: 3 GB
Bus Speed: 1.33 GHz
SOND HRV – 1500 HDV deck -
Tom Wolsky
April 3, 2008 at 3:00 pmWorks for me. You might try trashing preferences. Or explain exactly what you’re doing.
All the best,
Tom
Class on Demand DVDs “Complete Training for FCP6,” “Basic Training for FCS2” and “Final Cut Express Made Easy”
Author: “Final Cut Pro 5 Editing Essentials” and “Final Cut Express 3.5 HD Editing Workshop” -
John Barnard
April 4, 2008 at 2:38 amFor example, you can usually alter the in point of a video clip on the timeline without altering the audio in point by command-clicking the edge of the video clip and just dragging it. I’m sure it’s a simple setting somewhere but for some reason I can’t find it.
Final Cut 6
Mac Pro
Memory: 3 GB
Bus Speed: 1.33 GHz
Tom Wolsky
April 4, 2008 at 2:42 amNo, no, no. That’s Opt-click. Cmd-click allows you to select multiple items.
All the best,
Tom
John Barnard
April 4, 2008 at 3:47 amI see. I was apple-click on final cut 5. Whatever the case, neither of those work now. Could it be a system setting in OS?
Final Cut 6
Mac Pro
Memory: 3 GB
Bus Speed: 1.33 GHz
Tom Wolsky
April 4, 2008 at 4:04 amIt has never been Cmd-click. It has been Opt-click since v1. Opt-click is a toggle function. If linked selection is switched on, as it normally is, Opt-click will allow you to select video or audio separately. If linked selection is switched off, then Opt-click will act oppositely, selecting both the video and the audio.
All the best,
Tom
John Barnard
April 4, 2008 at 4:54 amIndeed it should. But I swear to that I’ve tried it with linked selection on and off with no results. Sorry Tom, don’t mean to be difficult here but I’m really beginning to think it’s some system setting.
Final Cut 6
Mac Pro
Memory: 3 GB
Bus Speed: 1.33 GHz
