Activity Forums Apple Final Cut Pro Legacy Apple Cinema Display
  • Apple Cinema Display
    Posted by Joseph Wilkins on April 23, 2007 at 9:16 pm
    Has anyone ever used an apple cinema display as a field monitor? It has a DVI plug, but you can get a DVI to component video adaptor that in theory should work. Anyone?
    Thanks…. Also, does anyone use an apple cinema display to do color correction? Can it be calibrated and used as such?
    Jerry Hofmann replied 19 years, 4 months ago 2 Members · 1 Reply
  • Jerry Hofmann
    April 23, 2007 at 9:25 pm
    There is a way to use it.. problem with your method is that it’s a progressive scan monitor and you’re feeding it interlaced video….plus you can’t calibrate it.
    But there’s a fix for that! If you have a 23″ display, Matrox MXO works like a charm and even has blue only and proc amp controls to make it a viable field monitor.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
