Activity Forums Blackmagic Design Apple cinema display & Multibridge Pro
  • Apple cinema display & Multibridge Pro
    Posted by Ikusmen on May 10, 2007 at 5:04 pm
    Hello:
    First, sorry about my english.
    In our small video company works in Betacam SP. Is possible to connect an 23inch Apple cinema display via HDMI output in Multibridge Pro to preview in SD mode, and via SD component in CRT monitor at same time.
    And… how?
    Thank
    Luke Maslen replied 19 years, 4 months ago 2 Members · 1 Reply
  • Luke Maslen
    May 11, 2007 at 6:28 am
    No it is not possible to connect a DVI-based display, such as the Apple 23″ display, to the HDMI output of Multibridge Pro. The two choices would be:
    1. Connect a HDLink to the spare SDI output of the Multibridge Pro and the connect the Apple 23″ display to the HDLink.
    2. Multibridge Extreme has a DVI output you can connect to the Apple 23″ display.
    Both Multibridge Pro and Multibridge Extreme include component analog input and output which can be connected to your Betacam SP deck or used for analog monitoring.
    Regards,
    Luke Maslen
    Blackmagic Design
