Activity › Forums › Apple Final Cut Pro Legacy › Append clip to multiclip angle
  • Append clip to multiclip angle
    Posted by Paulo Jan on July 13, 2007 at 6:19 pm
    Hi all:
    Is there a way to append a clip to a certain angle in a multiclip? For example, if you’re shooting with Panasonic P2 cards and one take spans two cards, it will be imported into FCP as 2 separate clips. Would it be possible to add both of them to the same angle? I thought about putting both of them in a sequence, but I’ve read that you can’t add sequences to multiclips. Of course, you can also add the 2nd clip as another angle and sync it by hand, but that’s a lot of work (usually it will be off by minutes, and the scrub tool for multiclips goes fraaame by fraaame… slow).
    Paulo.
    Paulo Jan replied 19 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
