Activity Forums Adobe After Effects Anyway to use Warp-stabilizer to multiple clips at the same time?
  • Anyway to use Warp-stabilizer to multiple clips at the same time?
    Posted by Kazumi Hatori on November 13, 2011 at 2:21 am
    I wonder if any of you try to apply warp stabilizer to many clips at the same time(i.e. 50)?
    It seems that all the effects run at the same time and then it hangs.
    So I can now only adding the stabilizer one by one.
    Anyway to let it render one by one by itself?
    Todd Kopriva replied 14 years, 9 months ago 2 Members · 1 Reply
  • Todd Kopriva
    November 13, 2011 at 4:43 pm
    No.
    Also, the Warp Stabilizer is very demanding of both CPU power and RAM. So, if you have a computer with a slow CPU or little RAM, then you certainly don’t want to try to feed the Warp Stabilizer a lot of clips at once (or long clips).
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
