Activity › Forums › Maxon Cinema 4D › anyway to use a wacom tablet w/ c4d?
  • anyway to use a wacom tablet w/ c4d?
    Posted by Colin James on May 10, 2005 at 3:20 pm
    Hey all, has anyone found a way to use a wacom tablet w/ cinema4d (we’re using r9)? It just goes everywhere…and when I used lightwave, there used to be a simple button that would switch it to Tablet Mode or somesuch.
    David Lewandowski replied 21 years, 4 months ago 6 Members · 7 Replies
  • 7 Replies
  • Chris Smith
    May 10, 2005 at 3:27 pm
    Does it go everywhere on the desktop? Meaning does it act normal, then get strange when using C4D? I assume you have switched between ‘mouse’ mode and ‘pen’ mode on the tablet and adjusted the tablet mouse speed settings?
    Chris Smith
    https://www.sugarfilmproduction.com
  • Joe Bird
    May 10, 2005 at 3:41 pm
    I have no experience with a Wacom, although I’ve read threads regarding this. Seems that there is a pref for
    graphic tablet in the application prefs. I think you turn on “Graphic Tablet”.
  • Colin James
    May 10, 2005 at 3:43 pm
    Yeah it does go all funky, and then the mouse starts acting odd even after I stop using the mouse…weird. Not that big of a deal…not worth having to adjust the tablet’s settings (especially if Im switching between apps) ..
  • Colin James
    May 10, 2005 at 3:47 pm
    haha im an idiot…completely missed it.
    thanks
  • Doug Bassett
    May 10, 2005 at 4:54 pm
    However, there is a bug. It won’t retain that pref setting for the next time you open c4d.
    Maybe try setting the pref that say say project layout on quit would work.
    Doug
  • Adam Trachtenberg
    May 11, 2005 at 1:00 pm
    [Doug Bassett] “However, there is a bug. It won’t retain that pref setting for the next time you open c4d. “
    It does for me.
  • David Lewandowski
    May 12, 2005 at 9:21 pm
    Yes. Turn on high-resolution points and your wacom should be fine. Make sure you’re updated via the maxon site; they often fix preference bugs like that right_away.
    d
