Activity Forums VEGAS Pro Anyway to change the constant bit rate for mainconcept mp4 render?
  • Anyway to change the constant bit rate for mainconcept mp4 render?
    Posted by Melanie Toasta on November 29, 2013 at 4:30 pm
    Anyway to change the constant bit rate for mainconcept mp4 render? It only offerd me only pre-chosen amounts like 4000000, 10,00000, etc. I want something in between.
    Ricardo Senise replied 12 years, 8 months ago 2 Members · 1 Reply
  • Ricardo Senise
    December 17, 2013 at 3:07 am
    There is only the pre defined bit rates in main concept .mp4. If you go for Sony AVCHD, there will be other choices as much as I know.
    There will be not so much difference between the bit rates in terms of size. Maybe going for the highest one you will be overkilling your render.
