Activity › Forums › AJA Video Systems › Anyone using variable frame rate DVCPRO HD?
  • Anyone using variable frame rate DVCPRO HD?
    Posted by Otis F on June 22, 2005 at 11:35 am
    Hello,
    I am about to embark on a project shot exclusively on a Varicam, I’m totally confused about this format, specifically the variable frame aspect, I wonder if anyone can clear the muddy waters.
    Firstly the system we have is FCPHD on a G5 2.7 with a Kona 2 and an IO LA. We also have a 23″ HD Display connected to the Kona 2 via a Blackmagic HD Decklink box.
    The project has been shot at variable frame rates with the end result being a 25p programme-(UK). My initial workflow idea was to hire a AJHD1200 for a couple of days and to digitise all the footage onto a big firewire drive using the DVCPro native codec, and then cut it up. The majority of the footage has been shot at 25p but there are a few tapes that have been shot at 50p and 60p.
    So what is the best way to get around this.
    Would the best workflow be to get those 50p and 60p tapes converted, which I assume would mean being put onto other tapes via a FRC running at 25p? Or could I use the FRC plugin which I downloaded from Panasonic? I’ve heard that if you use the HDSDI input then there is no need for a FRC, I don’t know how true this is. This may be an alternative workflow, I’m assuming that we could do this and downconvert and then online elsewhere as we don’t have the necessary hard drives for full HD.
    Sorry for my ignorance, but there seems to be a lack of knowledge on all things HD over here in Blighty.
    Thanks in advance.
    Otis F
    Otis F replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
