Anyone using FCP to edit PAL DV and output via SDI?
I shoot documentaries on DV and recently HDV for broadcast. Since upgrading to v.5 I’ve noticed that outputting my DV timeline to 8bit uncompressed SDI with a decklink extreme results in a flickering line at the top of the screen. As I had a broadcast deadline I cropped it out and recorded.
This has only happened with v.5 and is I think an FCP issue rather than a decklink driver one (something to do with changing the field order of PAL DV…..)Does anyone else notice this and is there a way around other than cropping???
Johnny White
