Activity › Forums › VEGAS Pro › Anyone tried an AMD dual opteron, dual-core motherboard with Vegas??
  • Anyone tried an AMD dual opteron, dual-core motherboard with Vegas??
    Posted by Wade Harrington on October 27, 2005 at 3:55 am
    Just wondering if anyone has tried running Vegas 6 on a dual opteron, dual-core motherboard. This would be like having 8 processors….I’m thinking of building one with 2 265 chips..
    James Green replied 20 years, 11 months ago 5 Members · 6 Replies
  • Chris Borjis
    October 27, 2005 at 4:15 pm
    2 cpus x 2 cores each, wouldn’t that be 4 cpus?
  • Wade Harrington
    October 27, 2005 at 10:00 pm
    I think you are right. Unless they are HT chips too?? Not sure.
  • Greg Noss
    October 30, 2005 at 10:16 am
    Boris is correct. Dual/dual core opterons is 4 CPU’s. Intel makes the HT core chipsets which are equivalent to the dual core Opterons. I think the bigger question is ” Will Vegas run on Windows XP 64?” because the Opterons are 64 bit CPU’s. That is where you will get the biggest increase in performance from.
  • Terje A. bergesen
    October 30, 2005 at 3:11 pm
    [Greg noss] “the Opterons are 64 bit CPU’s. That is where you will get the biggest increase in performance from”
    This is more of a myth than anything else. There is nothing inherent in 64 bit computing that makes it faster. In fact, there are a number of things that may make it slower. There isn’t much in a 64 bit architecture that will make Vegas or similar style of software faster. The 64 bit architecture allows for a far larger memory space etc, which isn’t really needed by most applications. Don’t expect 32bit to 64bit to have anything like the effect 16bit to 32 bit had.
    Terje A. Bergesen
  • Greg Noss
    October 31, 2005 at 8:23 am
    You are correct. However, I’ve seen benchmarks between Non-64 bit software and software made to take advantage of 64 bit processing. The 64 bit software benchmarks were significantly higher. Software not optimized for 64 bit processing does in quite a few cases run slower in a 64 bit enviroment. Maybe, I should have worded my comment differently. Is Vegas coded to take advantage of 64 bit processing?
  • James Green
    November 1, 2005 at 5:09 pm
    “Intel makes the HT core chipsets which are equivalent to the dual core Opterons.”
    Umm, no…HT is not the same as having 2 separate physical cores. Just cuz you can see two processors doesn’t mean you’ve got to. Besides, if an HT Pentium was the same as a Dual Core Opteron, why do you thin Intel would bother with the Pentium D?
    James Green
