Activity › Forums › Apple Final Cut Pro Legacy › Anyone tested the Dell 30″?
Posted by Gunleik Groven on January 11, 2006 at 10:10 amThe heading says it all…
Gunleik
Robert Conti replied 20 years, 8 months ago 12 Members · 13 Replies -
David Roth weiss
January 11, 2006 at 11:04 amThey just put them on the market like two days ago, I doubt anyone here has tested them extensively.
Walter Biscardi
January 11, 2006 at 12:18 pmafter reading about the drop frame issues with the 24″ Dell monitor I’m definitely not going to be the first on the block to test it.
Personally, I’m still loving the 23″ as the perfect sized monitor. 30″ and larger is really only needed if you plan to use it as an HD monitor, at least as far as I’m concerned.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Paul Ingvarsson
January 11, 2006 at 2:00 pmHmmm – I’m about to get one of the dell 24″ displays – I was under the impression that people here who have them are very happy with them and don’t suffer from the drop frames issues
Paul
Freelance DS/Symphony
London -
Shane Ross
January 11, 2006 at 5:19 pmI am very dubious of that Dell display drop frame report. NO ONE has reported any such problems on the Apple site, at LAFCPUG nor here. There are quite a few of us with these monitors, and I have not had any drop frame issues…and I have TWO.
Apple might be feeling the heat, or people who just happen to have the monitors are having issues with dropped frames and are blaming the monitors.
Shane Ross
Alokut Productions
http://www.lfhd.net -
Annaël Beauchemin
January 11, 2006 at 8:11 pmThe apple technote is very old. I remember having read it back in the days of FCP3. I guess that it has to do with CRT monitors not displaying some frames due to their low refresh rate, but the article isn’t very clear.
Beside, I thought that those Dell had DVI ports. As far as I know, there is no refresh rate to set wih DVI monitors… I wonder where’s the issue.
Steve Regian
January 11, 2006 at 9:00 pmWe have 4 Dell 24’s (2 per G5 system) and have nothing but good to say about them, especially for the price. All ours are running off DVI inputs and we do not use them for any playback, but we have no frame drop or any other issues (other than an Apple kinda guy having to look at a Dell logo.)
Guy
January 11, 2006 at 9:24 pmA litle bit of black tape covers the dell logo nicely!
BTW no problems with the 2405 here. I think this is all rumors, especially if it started from people blaming actual droped frames on the monitor – not some kind of skipping frames on the dell display only.
Shane Ross
January 11, 2006 at 10:06 pmI e-mailed the guy who runs the barefeats.com website and asked him about this….how many people reported this and how did they prove it was the monitor and not something else causing the skipped frames.
He e-mailed me back saying he had ONE well documented case, and that it dropped frames on FCP and on several games the user tried to play. When he dropped the resolution to a lower setting and switched to 75hz, the problem went away.
So this happened to one guy…or maybe a couple, and could easily be a conflict with the monitor and something else…seeing that every other person I have heard from with this monitor has no problems whatsoever.
It is a rumor that is spreading too darn fast.
Shane Ross
Alokut Productions
Jeremy Garchow
January 11, 2006 at 10:19 pm[Shane Ross] “It is a rumor that is spreading too darn fast.”
Agreed, I have not seen the problems that this doc is claiming either and I run the 24″ Dell.
G5 Dual 2Ghz <> 4GB RAM <> FCP 5.04 <> Kona 2
ATTO 42XS <> Huge Systems 4105 Fibre
OS 10.4.2 <> QT 7.0.3
