Activity › Forums › Blackmagic Cameras › anyone knowing the real impact of compressed raw 12 stops in the blackmagic production 4k ?
Posted by Evans Briceño on August 18, 2013 at 1:31 amI’m stuck to decide wich will be the better choice between the original BCCM vs the Production 4K.
does someone have any new knowlege about the real performance in low light and Dynamic range with the upcoming compressed raw ?
best regards
Evans
Evans Briceño
BLUE films
Caracas, Venezuela.
VZLA. +584166352066 / +582122838114 / USA +1-718-673-3326
virtualevans@gmail.com / contacto@virtualevans.com / http://www.virtualevans.comEvans Briceño replied 13 years ago 5 Members · 11 Replies -
John Fishback
August 18, 2013 at 4:09 pmUntil the camera is released to testers no one will know. With the BMCC and Pocket camera there was footage months before the camera’s release. IMHO, it’s a bit ominous we haven’t seen footage. BM must not be happy with what they are seeing in the lab.
John
MacPro 8-core 2.8GHz, 16 GB RAM, OS 10.7.4, QT10.1, Kona 3, Dual Cinema 23, ATI Radeon HD 5870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 3 (FCP 7.0.3, Motion 4.0.3, Comp 3.5.3, DVDSP 4.2.2, Color 1.5.3)
FCP-X 10.0.7, Motion 5.0.6, Compressor 4.0.6Pro Tools HD 10 w SYNC IO & 192 Digital I/O, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec DSP Monitors, Prima CDQ120 ISDN
Evans Briceño
August 18, 2013 at 4:52 pmHi john, thanks for the response. Do you think is a wise choice to buy the bmcc despite the promise of global shutter, s35 sensor and 60 fps of the 4k? The thing is I’m going to NY next week and I’m diying to buy the camera. Something tells me that compressed raw and the downgrade of the DR will change a lot the quality of the camera. Think to wait six months or a year for the 4k seens an eternity.
Evans Briceño
BLUE films
Caracas, Venezuela.
virtualevans@gmail.com / contacto@virtualevans.com / http://www.virtualevans.com -
John Fishback
August 18, 2013 at 6:15 pmI can’t answer that. If you need a camera right away, the BMPC isn’t available. But, it’s possible it will be released as stated in a few weeks. If you need 4k you have to wait a bit or go with another camera. I was on a waiting list for the BMCC MFT, but changed that to a BMPC. I’m thinking of going back to the BMCC as I don’t really need 4k and I have a number of MFT lenses. Compressed RAW doesn’t bother me. The RED uses compressed RAW.
John
Evans Briceño
August 18, 2013 at 6:52 pmI don’t need 4k. Actually what I need is 60 fps and the super 35 sensor ‘cos I have varius canon and nikon lenses. I don’t know if I can have have a mtf to canon adapter, since I prefer the mtf mount to have the choice of pl lenses.
Evans Briceño
BLUE films
Caracas, Venezuela.
Deleted User
August 19, 2013 at 2:12 amThe BMPC-4K does not record 60 fps.
Its top recording frame rate is 30p.
There is no such thing as a MFT-to-EF lens mount adapter. In other words, a MFT lens can’t be used on a EF lens mount.
https://www.peterdv.com
Blog: https://herefortheweather.wordpress.com -
Evans Briceño
August 19, 2013 at 2:37 amJohn I red in tech specs the following:
Frame Rates
3840 x 2160p23.98,
3840 x 2160p24,
3840 x 2160p25,
3840 x 2160p29.97,
3840 x 2160p30,
1920 x 1080p23.98,
1920 x 1080p24,
1920 x 1080p25,
1920 x 1080p29.97,
1920 x 1080p30,
1920 x 1080i50,
1920 x 1080i59.94.I thought the 4K didn’t record at 60 fps but some friend show me this chart and Abel cine shows the same. Did you have a different info at he NY event?
And in other hands maybe I’m confusing my undestanding about the adapter, since I’m not a native english speaker, I ment something different. I would like to use my EF glases (nikon and canon) with the BMCC MTF mount. Is there an adapter for this? maybe is EF to MTF mount is the way to write it down?
Evans Briceño
BLUE films
Caracas, Venezuela.
John Fishback
August 19, 2013 at 3:29 pmI haven’t read of the camera doing 60fps. As for adaptors, I’ve used a Nikon to MFT adaptor from Novoflex. Here’s one for Canon to MFT. There are other adaptors out there including one from Redrock Micro that powers the lens. Remember the BMCC’s MFT mount is passive.
John
Chris Tompkins
August 19, 2013 at 7:34 pm59.94i. or. 60i. Is NOT 60 FPS
That’s 60 fields or 30 framesChris
Deleted User
August 20, 2013 at 5:19 pmA BMPC-4K camera can output a live interlaced 1080 HD-SDI signal. For example, for use with an external video switcher or other gear.
The BMPC-4K will not record interlaced video internally to a SSD.
Again: The BMPC-4K will not record 60 (or 50) fps. Its top recording frame rate will be 30p.
Matthew Sonnenfeld
August 21, 2013 at 2:12 amIt’s crucial to understand that 59.94 is not an overcranked frame rate. This is an interlaced format that as mentioned above refers to roughly 60 fields which plays back at a 30 fps speed though they are not 30 progressive frames.
Recording 60p would mean that it is recording 60p to be played over a 24p time base. the BMPC 4K does not do this nor is it even capable via firmware. Interlaced data rates are also far smaller so don’t expect that if it can handle 59.94 interlaced that it can handle 60 progressive.
Co-President at fourB Productions, Inc.
Blackmagic Cinema Camera, RED Scarlet-X, Panasonic HPX170, Canon 7D
2011 Macbook Pro 17″, 2.3 Ghz Quad Core, 16GB RAM
2008 Mac Pro 2.6 Ghz 8 Core, 10GB RAM
AJA IoXT, Blackmagic Intensity Pro, Blackmagic Mini Monitor
Adobe Production Premium CC, Avid Media Composer 7, Final Cut Pro Studio 3
