Activity › Forums › Avid Media Composer › anyone know the resize % for 16:9 footage in 4:3 sequence?
  • anyone know the resize % for 16:9 footage in 4:3 sequence?
    Posted by Milton Hockman on March 16, 2006 at 6:00 pm
    I have 16:9 footage in a 4:3 comp. I don’t have a resize filter to automatically compensate the difference. So , i am using the normal resize filter.
    anyone know the height % correction to make it look 16:9? I think it is between 80-85%
    also, what about the height % correction to stretch it out to fit in the 4:3. I think it is around 120 %
    Chris Bové replied 20 years, 6 months ago 5 Members · 5 Replies
  • Jon Zanone
    March 16, 2006 at 7:30 pm
    Look in the reformat section of the effects pallette. Apply a 16:9 and it works like a champ…
    Jon
    “So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
    Del Amitri – “Make it Better”
  • Milton Hockman
    March 16, 2006 at 8:09 pm
    i dont have that in my avid. it is a media composer
  • Kryyn-01
    March 16, 2006 at 10:33 pm
    With “resize”, I let the Horizontal at 100% but lower the Vertical to 77%. If you do not want to lose information behind the 4:3 tv plastic frame, I suggest H 88% and V 65% (for 16:9 footage) for a dvd output. It fits for my tv back home.
    I don’t know if there is a better way without proper hardware.
    Good luck
  • Dave Schweitzer
    March 17, 2006 at 3:33 am
    For animorphic 16:9 footage to be letterboxed into a 4:3 show, I like to use a resize or 3D warp with vertical set to 75 and horizontal at 100. I also crop a couple lines off the top and bottom to hide the alternating half-line of video sometimes visible at top n bottom.
    Logically the inverse would be 125 vertical to 100 horizontal, and then you just position it up or down to taste.
    dS
  • Chris Bové
    March 21, 2006 at 5:29 pm
    … or just put a mask on top & bottom, allowing you to move the image up or down under the mask. Yeah you’ll lose part of the vid, but the finished product will look a bit better (not squished or strtetched).
    ______
    /-o-o-\
    \`(=)`/…Pixel Monkey
    `(___)
