Activity Forums Apple Final Cut Pro Legacy anyone know how to make 60p work in FCP?
  • anyone know how to make 60p work in FCP?
    Posted by Micah Ginn on October 31, 2006 at 5:45 pm
    I have shot footage in HD 60p (using JVC) and when imported into FCP, the footage will play in the preview window, but not on my timeline.
    I have tried to reset the sequence settings, but to no avail. Anyone had this problem? Anyone fix this problem?
    Shane Ross replied 19 years, 10 months ago 2 Members · 2 Replies
  • Shane Ross
    November 1, 2006 at 12:17 am
    YOur sequence settings need to match your clips settings exactly. Did you use an Easy Setup when you started the project and before you captured? Then if you make a NEW sequence, and discard Sequence 1, that new sequence should work.
    Or you can use this trick:
    http://www.proapptips.com/shane NON STANDARD CODECS IN FCP
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Shane Ross
    Shane
    Littlefrog Post
    http://www.lfhd.net
