Activity › Forums › Apple Final Cut Pro Legacy › anyone know a inexpensive way to hook up a tv monitor to my computer? without buying a new video card?
Posted by Milton Hockman on September 26, 2006 at 6:04 pmi dont have the money to buy a tape deck anytime soon (that is why i dont want to buy a new video card,) so i was wondering if there was an inexpensive way to hook up a tv monitor to my g5 computer so i can preview what my stuff looks like on a tv before sending it out.
id want to preview FCP and AE on the monitor.
the tv monitor i want to hook up accepts, composite, and s video inputs.
anyone have a suggestion?
Motion Graphics Artist and Non-Linear Editor
Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more.Dan Riley replied 20 years ago 8 Members · 15 Replies -
Ed Dooley
September 26, 2006 at 6:13 pmMy first suggestion would be to change your tag-line until you have a monitor. 🙂
Do you have a camera? You can run it through that if you do.
Ed -
Gunleik Groven
September 26, 2006 at 6:18 pmNote
If you’re editing DV – you’ll be able to monitor through the camera. If not, you’ll have to shel out for a card and a production monitor.
Gunleik
Shane Ross
September 26, 2006 at 7:20 pmAs others said, use your camera:
#8 External Monitor Viewing.
Shane’s Stock Answer #8:
A simple path is mac > firewire > camera or deck > rca cables > tv
Then start up your camera and tv, then open fcp.
Then go View > External video > all frames
Video playback should be Apple firewire NTSC (If you are using an NTSC set)
Audio playback should be Audio follows VideoTechinially, this should send synched video to your TV
If for some reason you can’t view your timeline on your external monitor, there are a few things to try:
1) Make sure that the camera/deck is connected and powered on BEFORE you open FCP.
2) In the Final Cut Pro menu select AUDIO/VIDEO Preferences and make sure your signal is being sent out thru Firewire DV.
3) Go to the menu and select VIEW>EXTERNAL>ALL FRAMES.
4) Click in the % box above the image and select FIT TO WINDOW.
5) Go to VIEW->refresh A/V devices
6) Make sure the Log & Capture window is closed
If you want it to play in both the canvas and the external monitor you need to go to the FINAL CUT PRO menu and select AUDIO/VIDIO settings and make sure MIRROR ON DESKTOP is selected under the PLAYBACK OUTPUT section
Shane
Littlefrog Post
http://www.lfhd.net -
Milton Hockman
September 26, 2006 at 7:51 pmtoo expensive for me, but is exactly what i was talking about. i could get a video card for that much.
Software expertise include: After Effects, Avid Xpress Pro, Final Cut Pro, Dvd Studio Pro, Photoshop, and more. -
Milton Hockman
September 26, 2006 at 7:53 pmi dont have a camera.
and the mxo matrox is too expensive. it said $995. i can get a video capture card for around that price.
i was thinking something cheap like a analog to digital converter box. or something????
Dan Riley
September 26, 2006 at 8:13 pmI don’t know what you want to spend, but go on eBay and find a used
Sony (or other) consumer DV camera, making sure it has s-video out.
You feed it with firewire from your G5 and take the output video to
your monitor and the output audio to your mixer-out to your speakers.
The video quality will be pretty much the same as any card.
This should cost you very little.Dan
Shane Ross
September 26, 2006 at 8:15 pmCanopus ADVC 110, or 300 will work for you. about $300-$500.
Shane
Littlefrog Post
Dan Riley
September 26, 2006 at 8:20 pmI went to ebay and found this, which should work just fine:
https://cgi.ebay.com/Sony-Handycam-DCR-HC30-camcorder-mini-DV-video-camera_W0QQitemZ270033183597QQihZ017QQcategoryZ20333QQrdZ1QQcmdZViewItemdan
