Activity › Forums › Apple Final Cut Pro Legacy › anyone if there is a hotkey short cut to make tracks visibile/invisible?
  • anyone if there is a hotkey short cut to make tracks visibile/invisible?
    Posted by Justin Tan on February 1, 2006 at 9:34 pm
    I’ve looked at the keyboard config and done a search with no luck. Basically I would ike to hide/unhide a level of vision for comparison using hotkeys, at the moment I am using undo/redo, but it’s not good because when i move to another location on the timeline I have to hide/show timeline again so the undo/redo trick works…
    any ideas?
    Justin
    Nick Meyers replied 20 years, 8 months ago 2 Members · 1 Reply
  • Nick Meyers
    February 5, 2006 at 2:45 am
    1- there is no shortcut to toggle track visibility in FCP 🙁
    2- rather than toggle track visibility, causing loss of renders,
    work locally by toggling CLIP visibility in the area you are examining:
    select clip/s
    CONTROL B toggles clip visibility
    if you want to turn a bunch of clips off to see one clip
    CONTROL S will SOLO selected clips
    cheers,
    nick
