Activity › Forums › Creative Community Conversations › Anyone have a Retina MBP?
  • Anyone have a Retina MBP?
    Posted by Jeremy Garchow on June 20, 2012 at 3:51 pm
    What does the HDMI output send?
    Can it be used as DVI with a cheap adaptor or are you stuck with video frame size and frame rates?
    If I am going to have storage, SDI capture/output, and an adaptor or two on Thunderbolt, it’d be nice if the HDMI out could used as a GUI monitor.
    Thanks for any insight.
    Jeremy
    Jeremy Garchow replied 14 years, 3 months ago 14 Members · 41 Replies
  • 41 Replies
  • Steve Connor
    June 20, 2012 at 5:30 pm
    https://www.macrumors.com/2012/06/20/retina-macbook-pro-can-run-three-external-displays-simultaneously/
    Is that enough screens?
    Steve Connor
    “The ripple command is just a workaround for not having a magnetic timelinel”
    Adrenalin Television
  • Chris Kenny
    June 20, 2012 at 5:44 pm
    [Jeremy Garchow] “Can it be used as DVI with a cheap adaptor or are you stuck with video frame size and frame rates?”
    You can use it with a DVI adaptor as a third general-pupose display output, yes.
    Digital Workflow/Colorist, Nice Dissolve.
    You should follow me on Twitter here. Or read our blog.
  • Jeremy Garchow
    June 20, 2012 at 5:47 pm
    [Chris Kenny] “You can use it with a DVI adaptor as a third general-pupose display output, yes.”
    at higher than 60Hz and 1080v?
  • Jeremy Garchow
    June 20, 2012 at 5:57 pm
    [Steve Connor] “Is that enough screens?”
    MOAR! MOAR! MOAR!
    Thanks, Steve. I was just wondering if that HDMI can be DVI as well, of it’s 1920×1080 @ 60P only.
    Jeremy
  • Andrew Richards
    June 20, 2012 at 7:31 pm
    OWC blog to the rescue!
    Best,
    Andy
  • Jeremy Garchow
    June 20, 2012 at 7:41 pm
    [Andrew Richards] “OWC blog to the rescue!”
    Thanks, Andrew. Steve, I didn’t click on all the links in your original post. My bad!
    1900×1200 was what I was looking for.
    This is great to know, and thanks everyone.
    How is it that this Macbook Pro is both a marvel and a stumper all at the same time?
    And why, oh why, do I need powerful portability in the very near future?
    Is it silly to buy this thing or is it silly to buy an older 17″?
    Or am I just being silly?
  • Andrew Richards
    June 20, 2012 at 8:10 pm
    [Jeremy Garchow] “Is it silly to buy this thing or is it silly to buy an older 17″?”
    I think it boils down to the GPUs and the ports. If you don’t mind the older AMD GPU and you really want built-in GigE and FW800, get the refurb 17″. If you’d rather have the new NVIDIA GPU and two Thunderbolt ports, get the Retina.
    I suppose you can mod the 17″ for more internal storage, but it won’t be fast storage unless you pay a ton for a big SSD.
    Not an easy decision.
    Best,
    Andy
  • Jeremy Garchow
    June 20, 2012 at 8:18 pm
    [Andrew Richards] “Not an easy decision.”
    I’m rather paralyzed.
    It’s not a cheap decision either.
  • David Lawrence
    June 20, 2012 at 8:37 pm
    [Jeremy Garchow] “I’m rather paralyzed.
    It’s not a cheap decision either.”
    Me too. I was really hoping to replace my aging unibody after WWDC but now I have no idea what to do.
    One thought is to maybe just go with the new non-retina MBP as they seem to have the same CPU/GPU options. I mostly work in clamshell mode, attached to a cinema display so maybe the premium for the retina display would be a waste.
    Still, when I’m dropping this amount of cash, I usually want the most state-of-the-art offering on the table.
    Really unsure about this…
    Jeremy, I presume you’re thinking retina for field work? Do you work in clamshell mode very often?
    _______________________
    David Lawrence
    art~media~design~research
    propaganda.com
    publicmattersgroup.com
    facebook.com/dlawrence
    twitter.com/dhl
  • Jeremy Garchow
    June 20, 2012 at 8:57 pm
    [David Lawrence] “Jeremy, I presume you’re thinking retina for field work? Do you work in clamshell mode very often?”
    I do not. If using it in clamshell, then yeah, the retina might be overkill as long as you don’t need the twin thunderbolts.
    I have been a 17″ since they started making them, so the form factor/loss of res is going to be a bit of a change.
    I need a laptop as I will be away from the office for a little while, but still need to work.
    There’s going to be a big green screen project in there as well as some other straight forward editing/cc. I need as fast as I can get in a portable machine.
    It’s nice to know the HDMI will support a single link DVI monitor for GUI.
    I will also probably buy the Sonnet ExpressCard Pro Thunderbolt thingy and be able to run my AJA ioExpress through it (hopefully) which will save dough on broadcast monitoring.
    I will need thunderbolt storage, though. 🙁
    [David Lawrence] “Still, when I’m dropping this amount of cash, I usually want the most state-of-the-art offering on the table. “
    I feel the same way. Buying a 15″ won’t be the most state of the art, but the new RMBP is pretty bleeding edge. I usually get a long life/lots of use out of my laptops so buying the newest thing makes a lot of sense.
    I have yet to make the time to go look at one in person, that will probably help make the decision.
    She loves me, she loves me not.
Page 1 of 5
