Activity › Forums › Apple Final Cut Pro Legacy › Anyone got an APPLE QUAD?
  • Anyone got an APPLE QUAD?
    Posted by Mikee2001 on January 6, 2006 at 10:22 pm
    Hi there! Don’t know if any of you might be able to help out. But I do need some! :)…
    I am continuously working on video clips, all 5 minutes long each.
    I need to stabilize every clip and have found a stand alone application along with a plug-in to effectively solve the problem. The results are truly AMAZING!!! and completely fixes any shaky shot.
    I have been using 2D3D SteadyMove on Premier Pro on PC for a couple of years now but would like to switch to Mac if I can solve the render speed issues.
    I have done a test render using a 1.42, 512mb memory Mac Mini and rendered a ‘5 MINUTE’ clip in ‘iMovie HD’ using the piStabilize plug-in.
    The rendering took 52 MINUTES!! Because of its complex function it is very demanding.
    The product for the Mac is called ‘iStabilize’ and I understand works either on its own or in iMovie HD, NOT Final Cut Pro… Although I thought you guys in here might like to know as it is a very effective product.
    I am asking anyone with a very fast APPLE or APPLE QUAD to check out the demo plugin and give it a go at rendering a 5 minute shot so we may compare the results.
    If you tell me the spec of your machine and render a 5 minute not stop shot with piStabilize in iMovie on ‘Default settings’. Let us know how long it takes to render and whether the outcome was effective. and hopefully find out the most effective Mac rendering setup!
    POST THE RESULTS ON THIS THREAD
    I’ll correlate the results for this Forum and post it next FRIDAY 13th JAN
    Mike
    To check out and download the plugin go here:https://www.istabilize.de/products.html
    Boyd Mccollum replied 20 years, 8 months ago 3 Members · 2 Replies
  • David Bogie
    January 8, 2006 at 5:01 am
    I have no experience with iMovie. Get After Effects, the builtin stabilization is fabulous but other plugs are available.
    bogiesan
  • Boyd Mccollum
    January 8, 2006 at 6:43 pm
    Render time for a 5 minute clip: 17’30”
    I’m running a Quad, 8gigs of RAM, and the stock GeForce 6600 graphics card. (I think it took me longer to figure out how to install the plugin and get a 5 minute clip onto the timeline in iMovie, then the actual render time).
    Boyd
    “Go slow to go fast”
