Activity Forums Adobe Premiere Pro Anyone get good slow mo with Twixtor plugin ?
  • Anyone get good slow mo with Twixtor plugin ?
    Posted by James Goodman on October 27, 2006 at 5:05 am
    I recently installed Twixtor 4.5 and tried a simple ramp down and ramp up during a dive clip. Premiere Pro ignored twixtor key frames and ran entire clip at 50% with very poor quality, much worse than simple 50% speed change using premiere only.
    Twixtor render time was about 5 min on a 12 sec clip (dual AMD Operton system 2GB Ram)
    I have yet to try twixtor in AE7
    Anyone have any good results with Twixtor in PPRO ?
    James Goodman replied 19 years, 10 months ago 3 Members · 7 Replies
  • 7 Replies
  • Craig Howard
    October 27, 2006 at 6:40 pm
    I do.
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Premiere Pro 2.0
  • James Goodman
    October 27, 2006 at 8:26 pm
    Thanks Craig
    At least I know it must be my settings – I have sent them with example to twixtor tech support but no response
    Did PPRo follow the key frames in your twixtor speed ramps ?
  • Craig Howard
    October 27, 2006 at 11:07 pm
    Yes.
    Craig Howard
    Auckland
    New Zealand
    Premiere Pro 2.0
  • James Goodman
    October 31, 2006 at 5:55 am
    Hi Craig
    Sorry to bother you for more info but the reply I got back from RevisionFX was that Twixtor will not work in PPro with field based footage and that I should import my DV footage into a PPro project set to Desktop and no fields. (I capture from a Sony DVCAM deck and if I put this in the Desktop setting then all footage has to be rendered). They said it was a bug in PPro with the DV codec.
    Do you mind telling me if you applied Twixtor directly to your captured DV footage or do you have to use a none field or progressive project setting ?
    Any leads would be appreciated
  • Craig Howard
    October 31, 2006 at 7:45 am
    My footage is progressive so this issue has never arisen for me.
    Craig Howard
    Auckland
    New Zealand
    Premiere Pro 2.0
  • Pierre Jasmin
    November 9, 2006 at 12:41 am
    The Field thing was my error
    Is it working now?
    Pierre
    RE:Vision Effects
  • James Goodman
    November 11, 2006 at 11:33 pm
    Thanks Pierre for your help and yes I did get it to work with the key frames
