Activity › Forums › Adobe After Effects › anyone else have a problem rendering a WMV file in AE 7?
  • anyone else have a problem rendering a WMV file in AE 7?
    Posted by Milton Hockman on June 15, 2006 at 6:34 pm
    i get an error when i try to render out a WMV file. It’s an error about IO mismatch.
    adobe website says to make sure my WMV settings and output module match so the error does not occur.
    but i can’t match them. if i choose 20 for my audio rate, i can’t match that in the output module. there is only a 22.
    anyone waht i can do to get my WMV files to export?
    Mike Clasby replied 20 years, 3 months ago 4 Members · 6 Replies
  • Aharon Rabinowitz
    June 15, 2006 at 7:19 pm
    On one of my machines I can’t even get into my WMV settings. If I try to use WMV or DVD, I get an unkown IO mismatch error .
    Is anyone else getting this or a similar problem?
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Tim Kurkoski
    June 15, 2006 at 7:29 pm
    Aharon and mr_gfx- what are the exact error messages that you are getting?
  • Aharon Rabinowitz
    June 15, 2006 at 7:54 pm
    Aharon Rabinowitz
  • Aharon Rabinowitz
    June 15, 2006 at 7:56 pm
    I get these messages even if i try to render a blank composition with nothing in it. As soon as I try to get into the WMV or MPEG-2 settings – WHAMO!
    Thanks, Tim.
    Aharon Rabinowitz
  • Milton Hockman
    June 15, 2006 at 9:40 pm
    I FIXED MY ERROR!!!
    i just found out that you can click on the audio export options in the Output Module an at the bottom there is a CUSTOM option. i used this to match my 20khz audio output, and that fixed my Mismatch Error.
  • Mike Clasby
    June 16, 2006 at 12:34 am
    I dunno, but I get much better wmv’x with thwe WMV Encoder, 2 pass variable bitrate, and easily tweakable, but then maybe AE & has the same options.
    https://www.microsoft.com/windows/windowsmedia/forpros/encoder/default.mspx
