Activity Forums Apple Final Cut Pro Legacy Anyone able to read this?
  • Anyone able to read this?
    Posted by Dan Browne on August 11, 2008 at 4:02 am
    Hey all,
    Final Cut is crashing a lot at the momet. Here is a segment from the crash log in console. To tell you the truth I haven’t got a clue of what any of this means. Anyone able to read it and tell me what it means? I can post more if its necessary, but it is quite long:
    0x9801e000 – 0x9802bfff com.apple.agl 2.5.6 (AGL-2.5.6) /System/Library/Frameworks/AGL.framework/Versions/A/AGL
    0x98126000 – 0x98148fff com.apple.AppleVAFramework 2.4.32 /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
    0x98419000 – 0x9842ffff com.apple.audio.CoreAudioKit 1.0 (1.0.0d1) /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
    0x98b31000 – 0x98c02fff com.apple.QuartzComposer 1.2.6 (32.25) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
    0x98c7f000 – 0x98c7ffff com.apple.quartzframework 1.0 /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
    0x99031000 – 0x99140fff com.apple.DiskImagesFramework 10.4.11 (115.2) /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
    0x991be000 – 0x991cbfff libbz2.1.0.dylib /usr/lib/libbz2.1.0.dylib
    0x991cd000 – 0x99210fff com.apple.ISSupport 1.0.3 (16) /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
    0x994c0000 – 0x9a2dbfff com.apple.QuickTimeComponents.component 7.5 (861) /System/Library/QuickTime/QuickTimeComponents.component/Contents/MacOS/QuickTimeComponents
    0x9a540000 – 0x9a544fff com.apple.QuickTimeH264.component 7.5 (861) /System/Library/QuickTime/QuickTimeH264.component/Contents/MacOS/QuickTimeH264
    0x9a546000 – 0x9a667fff QuickTimeH264.altivec /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.altivec
    0x9a7ee000 – 0x9a8befff com.apple.QuickTimeMPEG4.component 7.5 (861) /System/Library/QuickTime/QuickTimeMPEG4.component/Contents/MacOS/QuickTimeMPEG4
    0x9a8dd000 – 0x9aa4cfff com.apple.QuickTimeStreaming.component 7.5 (861) /System/Library/QuickTime/QuickTimeStreaming.component/Contents/MacOS/QuickTimeStreaming
    0x9b28d000 – 0x9b28efff com.apple.iokit.dvcomponentglue 1.7.9 /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
    0x9b29b000 – 0x9b2dffff com.apple.viceroy.codec 31.0 (31) /System/Library/Components/VCH263Codec.component/VCH263Codec
    Cheers,
    Dan
    Dan Browne
    Hawkes Bay, New Zealand
    Cloud South Films
    http://www.cloudsouthfilms.co.nz
    Dan Browne replied 18 years ago 5 Members · 7 Replies
  • 7 Replies
  • Peter Wiggins
    August 11, 2008 at 5:17 am
    Was this from the thread that crashed?
    Peter
  • Rafael Amador
    August 11, 2008 at 5:21 am
    Hi dan,
    What kind of footage are you editing and in what kind of sequence?
    in which moment FC crashes? When loading the Application? When doing any kind of operation?
    Which Mac are you using? What system/ What QT version?
    you don’t give much info.
    rafael
    http://www.nagavideo.com
  • Ron Lindeboom
    The only people who this means anything to are the machine-level coders of Final Cut. It doesn’t mean anything to users.
    Please do not post more of this here as it is gibberish that does not help diagnose the problem except for and by the coders and they do not interact with end users directly.
    Thanks for your understanding.
    Ron Lindeboom
    creativecow.net
  • Dan Browne
    August 11, 2008 at 5:47 am
    Its HDV footage, in a HDV sequence..? It usually crashes when we are doing a preview render. But recently it has started crashing more often. We are using a G5, quad core, 10gb of ram, 1.6tb hdd. OS X Leopard, and I guess the latest quicktime version, just did an update of everything with the software updater which I guess would update quicktime also, but that hasnt fixed anything either.
    Dan Browne
    Cloud South Films
  • Andy Mees
    August 11, 2008 at 6:01 am
    Dan
    You might want to post the log for the thread that crashed over on the Apple Discussions FCP forum … there are a few guts and all FCP users over there who would likely have a look for you.
    the part of the log that you need to post would be best explained by an example: here’s one
    Hope that helps
    Andy
  • Rafael Amador
    August 11, 2008 at 9:13 am
    Hi Dan,
    You have a big machine that shouldn’t have any problem dealing with HDV.
    I would start by trying to optimize the System, mostly if you just have updated: Maintenance, Repair Permissions and DiskWarrior or Techtools.
    There are always much more chances that FC crashes because a malfunction in Mac OX or QT than in the very FC.
    Rafael
  • Dan Browne
    August 31, 2008 at 2:59 am
    Just a followup, it seems to have been a corupt project or something similar. I went into media manager, and created a new project with that and it seemed to work fine after that. It still crashes, but only like once every two weeks kinda thing, which is obviously so much better than the 10 times a day we where getting sometimes. Thanks for all your help 🙂
    Dan Browne
    Cloud South Films
