Activity Forums Avid Media Composer anybody use Xpress Pro 5.x with an Areca RAID? playback problems
  • anybody use Xpress Pro 5.x with an Areca RAID? playback problems
    Posted by Praxisseizure on July 10, 2006 at 2:02 am
    I recently got an Areca 1130 RAID for use with my Xpress Pro machine.
    The card is a REALLY FAST, STABLE AND RELIABLE SATA2 RAID 5.
    except when using Avid… the reason I got it.
    Avid won’t play any media from it, yet it sees and captures to it just fine.
    Driving me absolutely crazy.
    I can take captured media from the RAID, move it to the inernal or firewire drive and it plays just fine! I can import media as well, but playback gives the same error.
    the error appears on attempting to play any clip from the RAID.
    Exception: FILE_OTHER, filename:(the OMF or MXF file desired to play)
    Exception: SYS_ERROR, status:87, msg:The parameter is incorrect.
    I have old media I transferred to the RAID (copying over the OMFI MediaFiles folder).
    The media plays fine from internal or firewire drives, but not the RAID.
    WHAT IS WRONG?! I know it’s not ‘avid certified’ hardware, but it’s no different than a Highpoint RAID (which does work with AXpro, but is much less reliable than the Areca)
    Praxisseizure replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
