Activity Forums Adobe After Effects Any way to use Refine Matte on a Track Matte?
  • Any way to use Refine Matte on a Track Matte?
    Posted by Mike Cantor on November 4, 2011 at 3:50 am
    I’ve created a Luma track matte by subtracting my composition from a clean shot and thresholding it. This works great but the edges are sharp.
    Refine Matte has worked great for me in the past when the mask is created by a chroma key. However I can’t find a way to use Refine Matte or anything similar on a TrkMat.
    Any suggestions?
    Thanks again!
    -mike
    Mike Cantor replied 14 years, 10 months ago 2 Members · 6 Replies
  • Roland R. kahlenberg
    November 4, 2011 at 7:39 am
    Did you actually try to apply Refine Matte onto your Track Matte Layer???
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia
    Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer
  • Mike Cantor
    November 4, 2011 at 4:13 pm
    That doesn’t work. Applying Refine Matte on a Track Matter layer looks for a Mask *on the track matte* layer. Since there is no mask it doesn’t do anything.
    Applying Refine Matte to the layer that’s being masked also doesn’t do anything — I guess it’s looking for a “Mask” within the layer and doesn’t apply to affect to a matte mask.
    -mike
    November 4, 2011 at 9:57 pm
    Refine Matte doesn’t require a mask. It works with a layer’s Alpha Channel AND all visual layers in AE have an Alpha Channel. Refine Should work on the Track Matte. I suggest that you take a look-see to find out what’s inhibiting Refine Matte from not working.
    HTH
    RoRK
  • Mike Cantor
    November 4, 2011 at 11:07 pm
    I think you just answered the question yourself of why it doesn’t work. Neither the layer being used as the matte nor the layer being matted have anything in the alpha channel. They are both completely opaque. That’s why Refine Matte as an Effect applied to either layer individually does nothing.
    -mike
    November 4, 2011 at 11:32 pm
    It’s indeed a strange way for Refine Matte to work. Perhaps selecting both the Fill Layer and the Track Matte layer and then precomping them will help. Then hopefully Refine Matte will work on the resulting nested comp.
    FWIW, the old Matte Choker works pretty well as does Channel Blur set to Alpha Mode).
    Cheers
    RoRK
  • Mike Cantor
    November 4, 2011 at 11:52 pm
    Ahh – Precomposing and using Refine Matte on the resulting comp that does have alpha info. That should work. Thanks!
    -mike
