Activity › Forums › Apple Final Cut Pro Legacy › Any way to turn NTSC to PAL?
  • Michael Gissing
    June 23, 2007 at 2:41 am
    The best way is not within a system like FCP but using external hardware. However, within FCP many recommend the Nattress Standards conversion filter.
    The way you suggested is not a good path.
  • Rich Rubasch
    June 23, 2007 at 3:08 am
    Compressor will do it too. I saw a marginal increase in quality with the Nattress plug in but the render times were much longer. Compressor did a pretty good job.
    Rich Rubasch
    Tilt Media
  • Walter Biscardi
    June 23, 2007 at 11:04 am
    [Michael G] “However, within FCP many recommend the Nattress Standards conversion filter.”
    I highly recommend this filter, especially over Compressor. Render times are longer, but the resulting image is cleaner.
    [Michael G] ”
    The way you suggested is not a good path.”
    Agreed, it just won’t work. You’ll end up with a very bad image.
    Walter Biscardi, Jr.
    HD Editorial & Animation for Broadcast and independent productions.
    All Things Apple Podcast! https://cowcast.creativecow.net/all_things_apple/index.html
    Read my blog! https://blogs.creativecow.net/WalterBiscardi
  • Graeme Nattress
    June 23, 2007 at 2:42 pm
    There are 3 methods I know.
    1) just let FCP or Quicktime do it. It just drops or adds frames, is quick, but looks BAD.
    2) my filter – field based, slow, but “good” quality
    3) compressor – can be set to look better than 1 or 2 above, but to get noticibly better than 2 and without artifacts I found the render time to be 40 times longer. So unbeleivebly slow.
    Obviously, I write and use 2 above, but the free watermarked demo is for you to see if the quality / speed ratio of the plugin is right for you.
    Graeme
    – http://www.nattress.com – Film Effects and Standards Conversion for FCP
  • Uli Plank
    June 23, 2007 at 5:04 pm
    I can only confirm this. Believe me, you don’ really want to use Compressor at it’s best quality setting for anything longer than a few seconds.
    Graeme’s filters offer a very good balance between quality, speed and cost.
    I you want something better than that, go for a service company which is using an Alchemist from Snell & Willcox or serious hardware from Teranex. But you will probably spend more on one job than for a full license of Graeme’s.
    No I’m not affiliated to his business
  • Bob Douglas
    June 25, 2007 at 9:52 pm
    I have used Graeme’s Standards Conversion filter for several years now, and have had great results. We even did a comparison with D-Beta footage that we sent out to be converted on a high end hardware system and the Nattress footage had the better quality, hands down!
    Again, no afiliation, just a satisfied user!
    Bob D.
    Bob Douglas
    FX Productions
    http://www.fxpro.net
