Activity Forums Apple Final Cut Pro Any way to show master clip from keyworded “subclip”?
  • Any way to show master clip from keyworded “subclip”?
    Posted by Oren Hercz on August 1, 2012 at 11:47 am
    Ok, so I’ve keyworded a portion of a clip and am looking at that, but then I want to see the entire source clip that it comes from. Is there any way to do this in FCPX. I can match frame from the timeline, but apparently not in the event browser when looking at a keyworded piece. I guess I could drop it in the timeline, then match frame, but that seems a little cumbersome.
    Thoughts?
    Thx,
    Oren
    Oren Hercz replied 14 years, 1 month ago 2 Members · 2 Replies
  • Michael Hofeldt
    August 1, 2012 at 11:51 am
    First select your keyworded range in the event browser. Then, if you select your Event from the event library (instead of the keyword collection), it will load the entire clip into the event browser with your range selected.
  • Oren Hercz
    August 1, 2012 at 11:53 am
    Thanks Michael. That works great!!! And is easy.
