Activity Forums VEGAS Pro Any way to re-combine an AC3 and an mpeg2
  • Any way to re-combine an AC3 and an mpeg2
    Posted by Dave Petteruto on June 13, 2010 at 4:39 pm
    I have an mpeg2 file and the related AC3 file that goes with it. Is there a way that I can get these into Vegas so I can edit the video and sound? I can import the mpeg2, but the AC3 doesn’t want to go onto the timeline. These were created in DVDA.
    Dave P.
    John Rofrano replied 16 years, 2 months ago 3 Members · 5 Replies
  • Mike Kujbida
    June 13, 2010 at 5:41 pm
    Vegas doesn’t import AC-3 files so, if you don’t have the source project and files, your only option is to Prepare a DVD (burning isn’t necessary here).
    Once the file is prepared, use the File – Import DVD Camcorder disc option, browse to the folder containing the prepared material and import the project back into Vegas.
    Be patient while this is happening as it may take a while, depending on the program length.
  • Dave Petteruto
    June 13, 2010 at 6:57 pm
    Thanks Mike, I’ll give it a whirl!
    Dave P.
  • John Rofrano
    June 14, 2010 at 1:17 am
    You can just use tsMuxeR to mux the streams back into one file.
    That will mux your MPEG2 and AC3 streams back into one .TS file which Vegas can edit.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Petteruto
    June 14, 2010 at 6:41 pm
    Thanks for the info on the software John. Have you had good luck with tsMuxeR? No problems with syc of audio & video?
    Dave P.
  • John Rofrano
    June 14, 2010 at 8:38 pm
    So far so good. I haven’t used it extensively to match audio and video. I mostly use it to concatenate HD files together without any loss from rendering. For that you use the Join button.
    ~jr
