Activity Forums VEGAS Pro Any way to go from multicamera back to non-multitrack editing?
  • Any way to go from multicamera back to non-multitrack editing?
    Posted by Jason Yip on July 7, 2010 at 8:06 pm
    I just started using the multicamera option in Vegas 9 to switch between 3 cameras. It works out very nicely. However, as I was going through the footage I noticed some things that could use tweaking. I’d also like to time shift some footage. Is there a way to go back to the standard editing layout once something has been cut using multicamera or am I stuck with this one multitrack?
    John Rofrano replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    July 7, 2010 at 8:19 pm
    No. The process is unfortunately one way only. This is why people still use 3rd party multi-cam tools like VASST infinitiCAM, Ultimate S Pro, and Excalibur. They all keep your original tracks intact when building the new master track allowing you to go back and forth.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
