Activity › Forums › Adobe Premiere Pro › Any way to get yellow box to go away when viewing multi-cam clips in source monitor?
  • Any way to get yellow box to go away when viewing multi-cam clips in source monitor?
    Posted by Nick Thompson on February 16, 2019 at 8:28 pm
    I’m sure this has been asked before, my apologies, but I haven’t been able to find anything definitive online. I want to view my multi camera source sequence in the source monitor, particularly in full screen mode, but both in full screen and not there is always that yellow box. Is there any way to get this to go away?
    Thanks for your help!
    Nick
    Trevor Asquerthian replied 7 years, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Todd Perchert
    February 18, 2019 at 3:07 pm
    Yellow box? Could you post a screen grab?
    TC
  • Nick Thompson
    February 18, 2019 at 6:27 pm
    Hi Todd,
    Thanks for the reply. I’ve posted a screenshot below. This same box appears when I do full screen.
  • Todd Perchert
    February 19, 2019 at 6:22 pm
    Do you only have one source in your multicam? I cannot get my multicam to do that. The yellow is on my selected source when viewing multicam. That just lets me know which source is selected. Not sure how you got to that point. If I load the individual source into my source window from a bin, it’s not there – only on the multcam. Maybe someone else can help…
    TC
  • Nick Thompson
    February 19, 2019 at 9:36 pm
    I do only have one source, and then to get it to show up when I do full screen video, I click on the wrench in the source monitor and select ‘Composite Video.’ Then it will appear fullscreen, but with the yellow box still around it. This is from the multicam sequence, not from the original individual source. The point is to be able to sync audio and video in a multicam sequence, and then watch that fullscreen without the distracting yellow box. Thanks again for your help.
  • John Pale
    February 23, 2019 at 4:11 am
    Collapse the multicam or disable multicam playback ought to do it. Once you are synced, do you still need it to be a multicam sequence for some reason?
  • Nick Thompson
    February 24, 2019 at 10:07 pm
    In most cases, I don’t need it to remain a multicam sequence. How do I collapse the multicam or disable multicam playback? Thank you.
    Nick
  • Trevor Asquerthian
    February 25, 2019 at 8:55 am
    To commit/collapse/flatten multicam (ie replace multicam instances with source clips but keep any effects applied) select clips, right click & ‘multicam|flatten’
    To disable multicam (ie prevent camera switching) select clips , right click & deselect ‘multicam|enable’
    To disable multicam viewing in program monitor (ie to see just switched line cut instead of line cut with multiviewer) use wrench icon on program monitor & select composite.
