Activity › Forums › Adobe Premiere Pro › Any way to get a list of edits applied to a sequence, not a clip?
  • Any way to get a list of edits applied to a sequence, not a clip?
    Posted by Amy Young on December 28, 2016 at 2:56 pm
    So I have received an EDL from someone. The goal is to make excerpts of the 90-minute sequence. The EDL applies to a single clip, i.e., the *.mov export of the sequence. But I would like to apply their EDL to the original sequence so I can choose other b-roll, etc.
    Maybe there’s a workflow I’m not aware of? I searched for ways to “make” a sequence into a clip or a subclip, but no luck in PP.
    I can make the excerpted pieces one by one in the sequence, of course, but I have this EDL and I want to use it programmatically if possible. ????
    Thanks for any ideas!
    Simon Ubsdell replied 9 years, 9 months ago 2 Members · 3 Replies
  • Simon Ubsdell
    December 28, 2016 at 3:31 pm
    If you got to File/Import and then select your EDL, Premiere will create a sequence automatically.
    You may or may not need to relink your media.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Amy Young
    December 28, 2016 at 4:02 pm
    Dear Simon, Thanks for the reply. I’m still not understanding you.
    What does the EDL refer to?
    Here’s my EDL:
    TITLE: EDL_v2
    FCM: NON-DROP FRAME
    001 Semantic_2016-12-19.mov V C 00:13:28:00 00:14:00:00 00:00:00:00 00:00:32:00
    *FROM CLIP NAME:SEMANTIC.MOV
    002 Semantic_2016-12-19.mov AA C 00:13:28:00 00:14:00:00 00:00:00:00 00:00:32:00
    AUD 3
    In my PPro project, “Semantic_2016-12-19.mov” is an imported single Quicktime of the final edit. In the same project, the final edit is a sequence called “Semantic_Edit_v999”.
    I want to use the in/out information in this EDL, but not use a .mov (or clip). If I change the EDL to refer to the sequence’s name “Semantic_Edit_v999” instead of “SEMANTIC.MOV” PPro asks to relink the media, and is looking for a file, not a sequence.
    Put another way, I want to use the EDL to make a new sequence by using in/out points on the timeline of a older sequence, not a new sequence from choosing in/out points from a pile of clips.
  • Simon Ubsdell
    December 28, 2016 at 5:18 pm
    Sorry, I didn’t understand your original question.
    The answer is that you can’t really use an EDL to reference another cut sequence.
    One thing you could do is make a new sequence containing the movie of your original Semantic_Edit_v999, and then import the EDL and add the resulting sequence on a video layer above. That way you would be able to see all the edit information from the EDL sequence.
    Simon Ubsdell
    tokyo productions
    hawaiki
